Auxiliary Battery Malfunction
Is this the main battery or one of those tiny "backup" battery that I need to replace? Is there a reset procedure just to see if this really need replacing?
Thanks in advance.
Thanks in advance.
You can remove the battery and trickle-charge it and see if the problem goes away. If the problem doesn't go away afterwards, you may need to replace it.
Since it is tucked behind the main battery (at least on my truck, it is), and it is not that easily accessible, if I were you, I'd replace it with a new one and be done with it.
^ +1.
If this is the one, how the hell do you get this out? lol 95% of it is under the carpet. Do I need to gut the trunk out to get to remove it?
I just did it.
Wasn’t easy, but it’s possible.
I didn’t want to remove side trunk side panel, because I didn’t want to pull off the trunk’s rubber seal.
