2015 ML400 brake fluid reservoir
Old Nov 25, 2017 | 10:25 AM
mjz3348's Avatar
2012 ML350
Is there an engine compartment diagram for the ML400?
I am looking to find the brake fluid reservoir. It's not obvious.
I haven't removed the engine cover yet - seems stuck.
Old Nov 25, 2017 | 11:47 AM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
the rubber hood seal that runs across the rear of the engine holds those panels in place.. peel the seal off (towards the front of the vehicle) and you can remove the drivers side panel to access the brake fluid reservoir.
Old Nov 25, 2017 | 12:28 PM
mjz3348's Avatar
2012 ML350
Thanks!! I knew it was hidden somewhere around the firewall. I see it now.
Old Nov 25, 2017 | 04:11 PM
mjz3348's Avatar
2012 ML350
I had a 'check brake sensor' warning come on and when I checked the pads, they look just fine - plenty of brake pad left (27,000 miles).
I decided to remove the sensor and "clean it" although they both looked fine. Problem seems to be intermittent.
