2015 ML400 rear brake sensor 'bolt'
Old Dec 2, 2017 | 02:53 PM
mjz3348's Avatar
2012 ML350
I need a replacement bolt which holds the brake sensor plug to the caliper.
When I took off the rear wheel to check my brakes, I noticed the hold down bolt is missing. The sensor plug was 'floating' freely held in place by the sensor wire.
Does anyone know the metric bolt size that would fit? Thanks in advance.
Old Dec 5, 2017 | 10:30 AM
kptaylor's Avatar
'14 ML350
https://www.mboemparts.com/auto-part...ar-brakes-scat
Don't see a bolt listed but do see a carrier for the ABS sensor. Could you be missing this carrier rather than a bolt? (#9 in the diagram.)
