Timing chain tensioner
Old Feb 4, 2018 | 12:45 PM
PositiveRate's Avatar
2013 ML350 4MATIC
Has anyone had this repair done outside of the warranty window? I’d like to get it done on my car. Only 9k miles but it’s a 2013 and out of factory warranty. Previous owner didn’t get any of this stuff done, so I’m playing catch up on some of the fine tuning...love the vehicle so far!
Will the dealership or MB pay for this? If not, anyone know how much (ballpark) it costs to get fixed?
Originally Posted by macmolly
If on starting your engine when its cold you get a four or five second chain rattle. There is a fix for this Take this topic Number to your dealer. L105-10-P-056435 (TSB) Version 1, Design Group 05.10, Camshaft drive. Date 07-16-2013. Validity Engine 276, 278, 157.
Brought my 2013 ML350 to Dealer with this information for this problem. They changed out chain tensioners. Install check valves etc. Hope this helps someone.
Old Feb 4, 2018 | 02:49 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
Can't see why not if there's a TSB on it. Can't hurt to try.
Old Feb 5, 2018 | 01:15 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Are the secondary timing chains actually rattling on your car - after only 9K miles? Yes, the TSB specifies what the fix for that specific problem is, but it is not a recall. You don't repair a problem that doesn't exist.
If you have to do the repair it takes about 7-8 hours to complete the work plus the cost of parts.
Old Feb 5, 2018 | 02:04 PM
2013 ML350 4MATIC
There are a couple longer threads in this forum describing the startup noise "2-3 second rattle" that is fixed by this tsb. Seemed to be unrelated to mileage on the affected engines. Yes, I have heard the rattle a few times at startup (no real pattern to it).
Also have heard what sounds like a worn serpantine belt for about 30-120 seconds after a cold start up, then it just stops and engine is as quiet as you'd expect from there on out. No idea if the two are related and what is or is not normal for the engine.
The short rattle seems to be a known issue on engines before 2014 sometime...
It was a warranty fix back then.
My ML runs great and neither issue appear to be something that is mechanically hurting the engine, but both are in the "unexpected" column...especially with such low mileage.
Old Feb 11, 2018 | 12:23 AM
Packrat555's Avatar
2013 GL450
i would disagree that is exactly what a tsb is for. I have a Acura TSX way out of warranty power steering hose rubbed and was leaking. Found tsb on this problem and Acura fixed at no cost.
tsb is a known mfg defect. If I had known it sooner. Could have brought the car in and they could have fixed the defective bracket before the hose rubbed through.
So yes if you know of a defective part you don’t wait until it breaks to replace it.
i believe a recall is different as it pertains to safety issues
Old Feb 11, 2018 | 12:57 AM
Diabolis's Avatar
https://en.wikipedia.org/wiki/Techni...rvice_Bulletin
