Differential fluid in 2014 ML 350 W166
Here is my question, I only bought 2l of the gear oil for the front/rear diff. For the front I filled up until I saw oil leak out. Which left me with about 1.1-1.2l for the rear. When I emptied the full liter and the remainder in the other bottle, no differential fluid leaked out like the front.
is that normal? I know I definitely have at the absolute minimum 1.05l in the rear diff.
I have diff oil in my basement for my BMW, maybe I can just top off with that.
It's your car - you can put in olive oil if you want to. Just don't blame Mercedes for your gas mileage going down (which it will) and when the diff prematurely fails.
fcp website also suggests liqui moly. Not trying to cheap out or use olive oil. Just looking for suggestions regarding fuschs vs liquimoly
Sheet 239.71 - updated yesterday - says that the approved diff fluids for the rear diff are
Product name 75W-85 Principal
Rhodium ST Pakelo Motor Oil S.r.l., San Bonifacio (VR)/ITALY
Mobilube FE Plus NG 75W-85 ExxonMobil Oil Corporation, SPRING, Texas/USA
MB 239.71/239.72 Hypoidgetriebeöl A 001 989 88 03- Mercedes-Benz AG, Stuttgart/GERMANY
Sheet 239.72 - also updated yesterday - says that the approved diff fluids for the front diff are
Fuchs TITAN SINTOPOID FE 75W-85 Fuchs Petrolub AG, Mannheim/GERMANY
So - you need to get either the Mercedes 239.71/239.72 Hypoid gear oil (A 001 989 88 03- ) or the Rhodium ST which is not available in NA.
Both diffs are essentially "filled for life", so why the rush to change the diff fluid now to something unapproved if your dealer will have the MB 239.71/239.72 oil in June?
Transfer case question, I have BLUE Pentosin ATF134 left over from my tranny service, was going to use that for xfer case service. Post above indicates Xfer case ATF 134 is red. Is there a difference beyond the color?
Yes, the Transfer Case takes the RED ATF 134: 001-989-68-03-13 (236.14) fluid, even though the Transmission requires the Newer BLUE ATF 134 FE: 001-989-77-03-09 (236.15) fluid.
The Fuchs Titan is not approved for the rear differential on a W166 - only for the front. You posted the same picture (front diff) twice. If it's approved in one but not the other, chances are that the fluid formulation itself has changed and that the two diffs on the W166 use different seal and/or other materials internally so the new Fuchs contains something that is not compatible with the seals on the rear diff but is fine in the front. Again, I don't know why you are rushing, but I would wait for another month and get the correct fluid from MB.
https://www.idparts.com/differential...t-p-14738.html
Yeah, really solid logic there dude.Yes, the Transfer Case takes the RED ATF 134: 001-989-68-03-13 (236.14) fluid, even though the Transmission requires the Newer BLUE ATF 134 FE: 001-989-77-03-09 (236.15) fluid.
Last edited by Leetom; Jun 1, 2022 at 08:33 AM. Reason: subscriber reference added
