ML166 bottom ball joint
Old Jun 3, 2018 | 11:52 AM
zenman63's Avatar
ML63 AMG 13 SLK 55 SLK350 AMG kit 07
As above anyone done the bottom ball joint?
Old Jul 29, 2021 | 09:32 AM
Songun's Avatar
C300
I'm working on it now. The 12P nut on the bottom of the ball joint. Don't have a tool for that, looks like I need 46mm 12p socket. Removed the knuckle, put on vise, heated the nut and the threaded part of ball joint and tried to push the ball joint with a hex but still get nothing.
Old Aug 2, 2021 | 04:14 PM
Songun's Avatar
C300
Update for any case you need. Ended up cutting the nut out and installing the new ball joint and new nut using a hex bit and channel lock, and then impact gun with impact hex bit. Took some time but it worked.
