Push start temperamental - 2014 ML350 BlueTec
Old Aug 29, 2018 | 12:01 PM
Jessamine's Avatar
ML350
My push start has been a bit temperamental lately. I'll push it, and it acts like it wants to start, with the dials all spinning up the way they normally do, and accessories come on but the engine doesn't fire. I can ALWAYS tell when I'm going to have a problem because the brake pedal isn't soft at all and doesn't move when I put my foot on it before attempting push start. I can pop the start button off, insert the key and it starts just fine.
Anyone else have this issue? If so, how was it fixed?
Thanks!
Old Aug 30, 2018 | 03:45 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
That doesn't sound like an issue with the push button start - it sounds like an issue with the brake pedal / parking brake. The car will not attempt to start without the brake pedal being depressed, so if it doesn't think that it is then it won't fire up. Next time when you feel the hard brake pedal (i.e when you can tell that it won't start with the button), do NOT let go of the brake pedal... pull the push button out and attempt to start it with the key, but I suspect that it also won't fire up.
Old Aug 30, 2018 | 04:19 PM
Jessamine's Avatar
ML350
I was kind of thinking that it was a conflict between the two. I'll do that next time and see what happens.
Old Sep 1, 2018 | 06:28 AM
audi40's Avatar
2020 GLE 450
I've experienced this as well on occasion, but I think usually another push or two on the brake pedal will get it to free up and startup.
Old Oct 2, 2018 | 05:46 PM
t3steve's Avatar
ML 350 Bluetec
Unhappy
Same problem here and its getting more frequent. Need to make a Service appt.
Old Oct 3, 2018 | 06:19 AM
Kartergreg's Avatar
2013 ML350 Bluetec, 2016 C3, 2020 Lincoln Aviator
Mine started doing that a few months ago. I wondered if the starting battery was going. I changed the battery in the ML and it has not done it since.
