W166 stuck in Park
Old Dec 14, 2018 | 04:47 PM
Morten Bonde's Avatar
w166
W166 stuck in Park
My w166 Gets stuck in p from time to time, the failcode is P172A00 direct select gear lever malfunction, does some have a clue about the issue.
both batteries are replaced newly
Old Dec 16, 2018 | 12:01 AM
Eric@wages's Avatar
2013 ML350 Base
check your battery. If you search this forum there are multiple people that have had their M's not go into gear. It is the battery that must be changed.
Old Dec 16, 2018 | 12:04 AM
Eric@wages's Avatar
2013 ML350 Base
oops!! sorry didnt read all your post.
Old Jan 5, 2019 | 06:20 PM
mikeh0917's Avatar
Mercedes ML350
Hey Morten...I have a 2012 ML350 also and am having the same issue (direct shift on column). I thought I had also narrowed it down to old batteries (both main and auxiliary) and was committed to getting them changed. However, I accidentally changed key sets (fobs) and seem to have no issues using my secondary set of keys (key fob). Both my primary and secondary key fobs have new batteries, so go figure??? You might give that a try. I will be posing this issue to my local MB dealer on Monday. Let me know if this also works for you and if anyone else has any ideas, please let us know. Thanks
Old Jun 8, 2019 | 04:48 AM
w166
This is still a problem for me have you solbes yours?
Old Jun 8, 2019 | 09:12 AM
mikeh0917's Avatar
Mercedes ML350
Yes. It appears to be related to a bad auxiliary battery. Both my regular and auxiliary were original and needed replacing. That solved the problem. Luckily I was able to switch FOBs as noted in the earlier post and get the vehicle out of my home garage and to a service center. Seems to be a poor design to cripple your vehicle because the auxiliary battery is bad. The other bad news is it costs around $800 to change both batteries. Again, poor design...they had to take the front seat out to replace the regular battery and the back cargo area floor and panel just to replace the auxiliary battery. I guess they build these for ease of manufacturing but they don't care about ongoing maintenance issues and costs. Just more annuity income for them!
Old Jun 8, 2019 | 12:01 PM
we47b1me's Avatar
'22 GLE 350 | '15 ML250 | '87 560SL | '19 GLC 300 | '12 C250 (sold) | '02 ML500 | '98 C230
You don't have to remove the front seat to change the battery, nor the rear cargo area for the aux one. If you paid $800 in labor, you were taken to the cleaners my friend.
Old Nov 16, 2020 | 07:43 PM
JurniorH's Avatar
ML350
I've read and researched until my eyes have closed. I have the same problem originally stated in this thread.
2013 ML350 decides at times it will not shift into gears after a while... After scanning a few errors that came up states the ISM was bad so it was replaced. Worked for about a week before going back to what it was doing.
Replaced the Auxiliary Battery even thought it's voltage is around 12.8v
Replaced Main Battery with new Champion AGM battery even though voltage was fine.
Took voltage reading from Alternator and no problem there.
Replaced FOB Key battery (after 4 energizer batteries kept getting "Replace Battery" message. Switched to Panasonic and message went away. Vehicle drove fine for 2 days now back to it's same.
Scanned again and the following code comes up - P172A00 - The Direct Select Lever is Faulty.
Additional code U1420 - CAN communication with the control module "N80 (SCM/MRM)' is faulty
Can't find anything that explains or deals with this code however almost convinced this is the problem.
Can anyone shed some light here??
Old Nov 16, 2020 | 09:16 PM
chassis's Avatar
2017 GLE350 4MATIC
Please see response in the other thread you replied to. Your SCM - steering column module N80 might need replacing.
Old Jul 9, 2021 | 12:03 AM
sams_6's Avatar
2014 ML350 4Matic
I had the same code - P172A00 - "The Direct Select Lever is Faulty" - and the car would not shift out of park. Well, the direct select lever WAS faulty. The entire outer steering column comes as a single unit with all levers - shifter, wiper, directional, etc. Cost $1200 including labor. You can find an individual shift lever on EBay but I was stuck out of state so this was not a home garage candidate for me.
