2012 ML350 - Blower problem - "No signal from resistor"
Old Jan 24, 2019 | 11:31 AM
pdeignan's Avatar
2012 ml350
I'm trying to troubleshoot the blower fan not working in my 2012 ML350. When the problem started, it would go in and out, then it finally went out for good. I got a new motor and resistor and replaced it but it still won't work. The code says "No signal from resistor". I saw another post where the problem was a faulty connector pin to the resistor. My mechanic says that's not the problem. He spent 2 days trying to figure it out and couldn't. He says the following:
- The blower (both old one and new one) works/spins when jumped
- Wire to the resistor has power and correct voltage.
- fuse is good.
- seems to think its a code issue that he can't reset.
- code says "No signal from resistor"
Does anyone have any ideas what it might be?
Old Jan 24, 2019 | 05:11 PM
Zuffen's Avatar
2002 Ml320, 2012 ML350 & Slk55
Has he checked the resistor?
Old Jan 24, 2019 | 07:52 PM
pdeignan's Avatar
2012 ml350
If it is the resistor, it would mean that it is bad on both the old blower and the new blower (new blower came with a resistor), so I doubt that it is. I did get it out of a salvaged vehicle so it is possible. I'll have to check that next... thanks
Old Jan 30, 2019 | 08:17 AM
tocipka's Avatar
2012 ML350 Bluetec
same issue
- fuse is good.
Had a very similar issue (if not the same) on my 2012 ML350. BTW: Voltage to the resistor does not tell you if the blower is getting enough power. In my case the problem was the connector under the passenger carpet on the right hand side. The high amp pin was not connecting right and melting the plastic. It looks like this connector can't handle the amps going to the blower (bad design by MB!). Raising the carper to get to it was a pain. I just removed the two ends of the thick wire from the connector and connected them outside (proper gauge).
Old Feb 3, 2019 | 11:36 AM
pdeignan's Avatar
2012 ml350
Thanks, I think that's what it is. I'm going to try to pull up the carpet in the next day or so and find out.
