Airmatic ADS problem ml350 2014
Old Mar 20, 2019 | 12:42 PM
Chrisking's Avatar
ML350 Bleutech 2014 W166 Sport package
Hi,
My ML350 2014 run very roughtly. The airmatic suspension work and have no leak. I get a look on each shock and I've never see leakage or anything else. My car seen like running without damping. So I suspect the ADS malfunction. Can somebody help me with this ? How can I fix the problem. Seen to be an electronic problem... Not sure. How can I do a reset?
Old Mar 20, 2019 | 05:16 PM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
Originally Posted by Chrisking
Hi,
Runs like engine? Or drives like suspension?
Is the engine running rough? Or is your suspension rougher than normal?
If suspension check each shock for fluid leaks. Also depending on age it just might be gone and need a replacement.
Because of your word choice in going to assume you are in Europe with a bluetec 350 diesel? If so I would also check your engine mounts if the engine running rough is an issue.
