Big Problem with DPF/EGR/Bluetec Off !!!
Old May 26, 2019 | 09:56 AM
baba777's Avatar
ML 350 Bluetec 2012
good day, I have a problem, maybe you can help me, I'm from Germany and drive a mercedes ML 350 bluetec 2012,
( Bosch EDC17CP46 )
a tuner from here disabled me AGR DPF Bluetec off and now for months the car goes without performance and if i do kickdown in limp mode, but without codes.
when i turn it off and on it works great the whole Time, but when i switch it off again and turn it on again After Some Minutes the same problem with limp mode, turn it on and off and it works great again.
I have to start the car everywhere I am 2 times.
I disconnected the nox sensor under the car, and staked the Bluetec ECU in the trunk and of course made the DPF empty.
No one here can help me !
do you know why it can be?
Do i forgot something to disconnect ?
do I have to stake out something from the AGR?
Thank you very much !!!
Old Jun 3, 2019 | 12:58 PM
baba777's Avatar
ML 350 Bluetec 2012
The failure code is „boost pressure too low“
what can i do please ???
Old Jun 3, 2019 | 05:02 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
If the issue started right after the retune, then the tune should be suspect
Old Jun 3, 2019 | 05:47 PM
baba777's Avatar
ML 350 Bluetec 2012
Maybe disconnect the differencial pressure Sensor ??
