Airmatic thump
Old Jun 28, 2019 | 02:15 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
Airmatic thump
I just noticed that my front airmatic makes a "thump" sound when going over a speed bump. The faster I go over it the more pronounced it is. Nothing on the back btw. Not sure if that is normal but have anyone with airmatics experience the same thing. If imthere was a problem with yours and was fixed what was the culprit?
Old Sep 6, 2019 | 03:29 PM
mistrykr's Avatar
ML350
were you able to find the solution?
Old Sep 9, 2019 | 10:05 AM
mistrykr's Avatar
ML350
Hi I finally was able to figure it out. Check ride height level sensor on rear. on mine, the link was seized which was making the airmatic drive stiff. I moved the link around to break the dirt/debris. now it is going smooth over bumps and pot holes with no thump sound. Before it was shaking my whole dashboard as well.
Check all the links on ride height level sensors for damaged, seized links.. Good luck and hope this helps.
Old Dec 27, 2019 | 02:20 PM
tjbrum's Avatar
mistryker,
thanks for post. I have exact same issue in the rear. Would it be possible to post a pic of the ride height level sensor you reference? Just so I know I, checking the right part.
