Advice needed on 2013 550
Old Jul 30, 2019 | 01:06 PM
shmelvin1's Avatar
none
I am considering purchasing a 2013 ML550 with 85k miles...here is a note from the owner, what do you guys think?
"There was an exhaust leak on the manifold that caused the valve seat to burn out on cylinder 5 at 68k. This is apparently common for #5 to have problems on this powerplant. it took almost 2 months to get the car back. They pulled the engine, replaced the head, cut the valves in and seated them and reinstalled. During that, they noticed an oil leak on the lines to cool the turbo on the left side… oil had leaked on the ECU, and sensors for cam position, o2 sensors, wiring harnesses. The result was they replaced all of those components. Changed the diff fluid, recharged the AC, did an alignment, serviced the transmission, etc. The engine pull resulted in a full clean up and loading of new updated software. I have the records for this."
Old Jul 30, 2019 | 01:53 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Cant help but that engine is used in various models to include the GL series. Should be a lot of info somewhere on this site. Personally, I wish I had a ML550( 2014 last year in ML) instead of my ML350.
Old Jul 30, 2019 | 04:07 PM
Matt-Dallas's Avatar
ML350
What’s the price you’ll be paying?
Old Jul 30, 2019 | 05:50 PM
shmelvin1's Avatar
none
$20K fully loaded P2 package.
Old Jul 30, 2019 | 09:48 PM
shmelvin1's Avatar
none
Moot point....it sold
