2013 ML350 Bluetec DPF/EGR/SCR delete 330HP/530TQ
Only a little bit of ammonia smell before delete. After delete, it just have diesel smell. It should not have ammonia smell unless you did not disconnect the connection from your adblue tank to exhaust system.
Maybe we're just describing the diesel smell differently. It does sound like its more hardware rather than software that's causing the smell. Maybe different tunes can bring small improvements, somehow i doubt it would bring a significant improvement to the smell (TBH I dont know enough about tunes though :/ )
the other one i was considering was JR Auto Tuning, those 2 i think were the only ones that were within driving distance vs me shipping my ECU to someone. There is the Calgary place GLK Super Fan used, and im sure there are more US based tunes also, maybe even more in Canada that I'm not aware of.
When i got to the tuning shop, Alex moved the vehicle in for me and check for the CEL. I have a CEL that I cannot get rid of. Here is my CEL
This is one of my old picture in my build thread, i actually don't have the 2nd code this time. I was able to solve it by change it my fuel filter. So I only have the first code.
Check out the file i upload, it a pdf file that explain for my CEL that the dealer has to disable
So Alex helped me code the vehicle and I got the latest stage 2 tune. After the tune, the smoke problem still exist, so Alex helped me to calibrate the fuel injectors again. This time it solved the problem. Sam suspected that my one and four fuel injector are plugged, that why it caused the smoke issues. he recommend some fuel injector cleaner from LM pro series. I am gonna get some from FCP euro and test it out. meanwhile, the car is running perfectly fine now. Minimum of smoke and only little bit diesel smell. In terms of power, it was like before, the new tune is more refine, little more smooth.
That is right, for the price of $1,699 plus labor and parts(approximately $2,500), you can have your ML350 push with 330HP and 530 TQ
This is my first time posting in the ML forum section but I am not new
I had a great success on my GLK DPF delete and always being a active member. How I call myself had a great success with the GLK DPF delete? what if I tell you I can achieve 4.8L/100km (49mpg) and probably better mpg with my GLK since I had changed with few things. If you want to know more, come check out my post in the GLK forum.[/QUOTE]Last edited by rapidoxidation; Mar 6, 2023 at 11:52 PM.
I know its an older thread. I am curious to find out more about this tune. Every tuner out there claim 275hp this is the only tuner Ive seen that claims he can get 330hp with a stage 2. Ive been searching online and I could not find a lot of information/videos of ML350s tuned and deleted.
I would appreciate links to videos/dyno results that prove he can tune it up to 330hp.
How is your ML holding up?
Thank you!
