2014 ML W166 ashtray light bulb replacement
Old Nov 15, 2019 | 12:26 PM
armiani's Avatar
W166
Exclamation 2014 ML W166 ashtray light bulb replacement
Anyone out there knows how to find and replace ashtray light and cigarette lighter illuminated ring light.
Please help!
Thank you.
Old Nov 16, 2019 | 03:31 PM
Rainers's Avatar
Are you sure you did not blow a fuse? Both rarely go out at the same time. Does the lighter work
Old Nov 17, 2019 | 09:33 AM
armiani's Avatar
W166
The lighter was dead so I did change the fuse and now is working perfectly fine both as a cigarette lighter n Phone charger.
I don’t think the fuse has to do with the ashtray light n illuminated cigarette lighter ring. I believe there is a bulb under so does anyone know how to get there n replace it with new. Checked on my friend 14 W166 both light are on n working so it has to be a burned out bulb.
thanks
Old Nov 17, 2019 | 05:39 PM
GLK Super Fan's Avatar
GLK250 ML350
thanks
Can you please tell me where the fuse is ? Mine lighter is not working
Old Nov 18, 2019 | 09:02 AM
Don_CA's Avatar
ML 350 Bluetec
List of fuses and locations: http://www.mercedesmedic.com/fuse-m-...00-550-63-amg/
Old Nov 18, 2019 | 10:08 AM
armiani's Avatar
W166
under the back seat is located the FUSE box
cigarette lighter fuse is 15amp blue first check is its blown is yes replace takes no more than 5min just did mine recently
Old Nov 18, 2019 | 10:50 AM
GLK250 ML350
Thank you!! I will check it out today
