Cornering lights turn on?
Old Jan 1, 2020 | 08:14 AM
paulwith's Avatar
ml350amg slk 320
Hi,new here.
Just bought a 14 ML350 with intelligent light system.UK spec.
I'm not sure if the cornering lights are working. Are they active when the light switch is in "auto?" or do I have to switch them on somewhere? I'm still trying to work through all the menus!
Paul
Old Jan 3, 2020 | 03:14 PM
drwolf's Avatar
2020 GLE350 2020 Toyota Rav4H AWD XLE
Originally Posted by paulwith
Hi,new here.
Paul
Do you mean the lights when you turn? the way ILS works is that if you put your high beams to on, you will see n "A" or auto, meaning that if the front windshield camera detects that you are in a super dark
area, high beams will turn on. the ML i had came with the ILS and it didnt have a light when you approached a corner, it works when you drive on a curve such that when you move the wheel the lights will move with it.
on the GLC i have and my Moms S550 (Both have the LED from lamps) they have the corner lights such that when you wanna turn or start a turn with a signal it will turn on.
Old Jan 3, 2020 | 03:39 PM
paulwith's Avatar
ml350amg slk 320
Thanks for reply, it seems to work now when lights are on dipped beam,not sure if an additional bulb comes on or the headlamp swivels?
