Transfer case replacement recommendations
Old Jan 4, 2020 | 01:41 PM
roger.perales's Avatar
ML350 Bluetec
I recently discovered that my 2012 ML350 needs the transfer case replaced. Is this a common issue or a manufacturing defect? The dealer wants to charge upwards of 6K to perform the service. Any recommendations?
Old Jan 4, 2020 | 03:20 PM
Zuffen's Avatar
2002 Ml320, 2012 ML350 & Slk55
The two lugs supporting the tensioner inside can fail.
There is a Thread on here about a DIY fix.
If it was me, I'd buy a used transfer and swap it over.
Old Jan 4, 2020 | 04:22 PM
ML350 Bluetec
Thanks Zuffen
I’ll find a mechanic that can do the swap. My Ml350 has around 150k miles on it so I wasn’t sure if this is something that happens at high mileage.
Old Jan 5, 2020 | 05:58 PM
VolaCola's Avatar
Someday an ML350
Hey roger, I found this thread a while back when I was researching potential problems with the W166. The guys talk about ordering rebuilt TC's from lisbontruck.com or cobratransmission.com if you are interested. Apparently it's a 5 - 6 hour job to swap them out.
https://mbworld.org/forums/gl-class-...50-diesel.html
Old Jan 5, 2020 | 06:16 PM
ML350 Bluetec
Hi VolaCola,
thanks for your info! I am going to reach out to the mechanic tomorrow. They were also quoting me 5k to 6k to do the work for the replacement.
Old Jan 5, 2020 | 07:11 PM
VolaCola's Avatar
Someday an ML350
Glad I could help. It sounds like the rebuilt TC's run around $1500 USD so it seems like it should be < $3000 total if you go the rebuilt route.
Let me know what happens.
Old Jan 16, 2020 | 03:18 PM
VolaCola's Avatar
Someday an ML350
So what did your mechanic have to say?
