Tyres for comfort!?
Old Feb 7, 2020 | 05:55 PM
paulwith's Avatar
ml350amg slk 320
Arrow Tyres for comfort!?
Probably an old topic but would appreciate an update.
I bought a 14 350 AMG recently.
I love the car with it's £20k of extras, but I'm not sure if can live with the harsh ride, I can feel every bump in our rubbish UK roads.Tyres are original Continentals.
It's Airmatic and I have replaced a rear shocker.
In older threads I see that some owners have replaced the Continentals with tyres which give a softer ride, Michelin Latitudes?
Can anyone suggest any tips to soften the ride and/or suggest what latest tyres would help.
Absolute priority is comfort over wear, handling or even price.
Need to sort it or it's going!
I had a 12 year old Kia Sorento which rode better!
Thanks.
Old Feb 7, 2020 | 06:54 PM
Gazwould's Avatar
S204 C250 CDI Sport
https://www.tyrereviews.co.uk/
Old Feb 8, 2020 | 09:21 AM
paulwith's Avatar
ml350amg slk 320
Thanks for that.
Seems to list all criteria except "comfort" which is the priority.
Old Feb 8, 2020 | 07:01 PM
WillieMack's Avatar
Mayback
Originally Posted by paulwith
Thanks for that.
Check your cold tire pressures and set them close to factory recommended (19 inch wheels 33-35 psi). High pressures (38 psi+) can cause the harshness/bumpiness.
If that doesn’t solve it, get Michelin Premier LTX.
Old Feb 9, 2020 | 07:48 AM
paulwith's Avatar
ml350amg slk 320
I'm running at 32 psi cold.
Wonder if it's worth trying Premiers on the rears first (tyres are all at 7mm) and a bit pricey! Any market for used rubber?
Also the load rating on the Premiers is 107, is that a bit high,make a difference? It's never fully loaded.
Old Feb 9, 2020 | 08:50 PM
Oldoarsman's Avatar
MB ML 350 4Matic, Sprinter 2500 High Roof Passenger
Another vote for Michelin Premier LTX...
Most comfortable/quietest tire I’ve ever driven, but they do not last.
Replaced at 30,000 miles with Michelin Defender LTX M/S...almost as smooth and quiet as the Premiers and they should last longer.
Old Feb 10, 2020 | 06:27 AM
paulwith's Avatar
ml350amg slk 320
Thanks,
Not concerned about wear, just looking for a smooth ride.
Did your 350 ride harsh before you changed tyres?
Old Feb 10, 2020 | 07:52 AM
Oldoarsman's Avatar
OEM Continentals replaced with Michelin Premier LTX
I replaced the OEM Continentals with Michelin Premier LTX tires. The Continentals were beginning to hydroplane and felt stiff. The ride was noticeably improved by the more forgiving feel of the Premiers.
Please note that I have the steel suspension in my ML350 4Matic.
