Front Crankshaft Seal Oil Leak - 2012 ML350 Bluetec
2012 ML350 Bluetec - W166
I have an oil leak coming from my crankshaft seal and have been putting off replacing it, but nows the time - are there any special tools needed to remove the pulley to access it? Any tips on removing/installing the seal?
Thank you so much in advance!
David
David
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
I too would first make sure it is not from the oil cooler seals. Crankshaft seals are not known to fail, although it the oil wasn't changed regularly and it was full of diesel all bets are off.
