Ml350 pre safe warning. Loss of power
Old Mar 28, 2021 | 10:44 PM
Robby Ch's Avatar
2014 ml350 bluetec
2014 ml350 bluetec. Pre safe limited, unable to shift into any gear. Blind spot inoperative as well. What could be the problem? Battery? Sensors?
File Type: mov
Old Mar 30, 2021 | 08:29 PM
Etienne Lau's Avatar
Ml350 bluetec
How old is the 12V battery? When was the last time you changed it? I wonder if the issue is caused by low/flaky 12V.
Old Mar 31, 2021 | 10:55 AM
Robby Ch's Avatar
2014 ml350 bluetec
Battery is about 7 years old. Battery when the vehicle is off is sitting at about 11.8V but is normal over 14 when car cranks over
Old Mar 31, 2021 | 01:46 PM
Ml350 bluetec
Well you just solved your own problem. These vehicles are finicky about seeing 12.X(12.5) volts. And they freak out when it see's that 11.8V. The 14.X volts means your alternator(charging system is doing it's job. So get a new battery.
Old Mar 31, 2021 | 04:23 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
+1 on the battery. Replace both batteries (main and aux SLA).
Old Mar 31, 2021 | 10:55 PM
chassis's Avatar
2017 GLE350 4MATIC
+2 on the battery replacement, both of them.
