Lopsided brake pads
Should I have done cleaned and greased that area? Is it normal for the pads to sit like that? Just want to make sure I didn't goof and now putting undue wear on the brakes.
Cheers for any advice.
As for swapping in/out, that would be impossible, as the inboard pads have clips for grabbing onto the caliper pistons and the outboard ones are flat.
I did see from my research that the OEM pads have adhesive on the back of the outboard pads. Not sure if that's the difference or if the adhesive is only to prevent rattling.
The mix up was from the weirdly cut edges on the pads that gave the illusion the pads weren't sitting flat. Had to look through the top of the caliper to see the mating surface.
Everything's good.
