Command fuse number
Old May 20, 2021 | 11:57 AM
paulwith's Avatar
ml350amg slk 320
Command fuse number
Hi
2014 Ml 350 2014
Can any one please advise the number and location of the fuse for the Command system (with TV) .I need to try to reboot he system It goes to "Mercedes Apps" and freezes when I turn on split screen for TV on the move.
Old May 21, 2021 | 11:42 AM
chassis's Avatar
2017 GLE350 4MATIC
I would go with fuse 101 or 21. One of them is in the driver's (LHD) end of the instrument panel, the other is under the right rear passenger seat.
Do you have the fuse allocation diagram? It is in the fuse box under the right rear passenger seat. It's Olde Schoole paper.
Do you have WIS? You need it.
Diagrams to get started with attached.
File Type: pdf
File Type: pdf
File Type: pdf
Old May 21, 2021 | 12:58 PM
paulwith's Avatar
ml350amg slk 320
Many thanks for that but what is WIS please?
Old May 21, 2021 | 02:33 PM
chassis's Avatar
2017 GLE350 4MATIC
It’s the dealer level service documentation. Use the search feature on this site and Google and it will explain. Available on eBay for around $10.
Do you have the paper fuse diagram?
Old May 22, 2021 | 01:05 PM
paulwith's Avatar
ml350amg slk 320
Will take a look if it ever stops raining!
Old May 24, 2021 | 10:11 AM
paulwith's Avatar
ml350amg slk 320
Hi again
Found the fuse diagram for the rear box.
Fuse 101 seems to relate to the trailer hitch and 21 to the "central display"
Are they the correct fuses? There are no fuses relating to command.
Old May 24, 2021 | 11:24 AM
paulwith's Avatar
ml350amg slk 320
Ps hope not a stupid question but to reset do I remove the fuse with ignition on or off?
Old May 24, 2021 | 09:57 PM
chassis's Avatar
2017 GLE350 4MATIC
Page 43 for the reset function in the COMAND manual.
More wiring diagrams attached.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
