ML AC Recall
Old Oct 25, 2021 | 12:03 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
ML AC Recall
I just dropped my 2015 ML off at the dealership for a moldy-smelling AC. From what I have read, there was a class-action regarding this problem and Mercedes is required to replace these HVAC units free-of-charge. However, the person I spoke to at the dealership said there was no such recall out. Can anyone confirm that there is a class action settlement requiring this? I want to be sure before I go in and start a fight.
Old Oct 25, 2021 | 08:28 PM
Etienne Lau's Avatar
Ml350 bluetec
Never heard of this class action or recall.
Old Oct 25, 2021 | 09:17 PM
JD101b's Avatar
https://www.lieffcabraser.com/defect...-benz-ac-mold/
Old Oct 26, 2021 | 03:50 AM
chassis's Avatar
2017 GLE350 4MATIC
No recall.
No parts replacement.
A “treatment” or “cleaning” may be provided.
The treatment or cleaning is not a permanent corrective solution. The wet socks smell will eventually return. It is caused by mismanagement of condensation.
The wet socks smell is an MB design failure, one in a shockingly long and equally shockingly serious list of design failures.
The most appalling of these is relatively common engine grenade at less than 100k miles. Several engines share this signature MB feature.
Old Oct 26, 2021 | 10:53 AM
Leetom's Avatar
2013 ML550 US spec. Air+Offroad pkg
Yes there is some settlement relief out there. You can Google it. Here is one site with more info. Dealer sounds shady claiming not to know of this common issue.
https://topclassactions.com/lawsuit-...it-mold-smell/
Old Oct 26, 2021 | 11:46 AM
threeMBs's Avatar
Only MBs - the best or nothing
As was stated by Chassis above there is NO recall, NOR there are any parts of HVAC that dealers have to change.
The settlement is basically that MB will provide a 10 year "warranty" for filters (cabin charcoal and pre-filter) and associated labor due only to smell IF it develops (and not part of 2yr maintenance replacement schedule for these filters) going forward AND that anyone who have already paid for filters and labor due only to smell in the past (and not part of 2yr maintenance replacement schedule for these filters) are due reimbursements if one can prove records of such service. MB dealers all know this since ML/GLE (and several other MB models) owners received notification regarding this "warranty" a couple of years back (with COVID my timing of actual notification year could be off a bit, but not the substance).
Old Oct 26, 2021 | 12:45 PM
JD101b's Avatar
I just got a text from my dealer saying I'd be eligible for 70% reimbursement of the repair. Still comes out to about $170.
Last time I got a service I had a new GLS450 loaner. This time I got a C300 that they forgot to clean before they gave it to me
Old Oct 26, 2021 | 01:14 PM
threeMBs's Avatar
Do you know what "the repair" is? My understanding is that it is cleaning of HVAC (labor) AND replacement of filters. Sounds to me that they're not charging for "cleaning" but are charging for filters.
Old Oct 26, 2021 | 01:43 PM
JD101b's Avatar
That is a good question. I do not know.
Old Oct 27, 2021 | 05:33 PM
C280 Sport's Avatar
MB’s of all kinds.
Never had any notification about this. I am curious about this. Did anyone get anything in the mail or calls from the dealers about this?
Old Oct 27, 2021 | 08:31 PM
Ml350 bluetec
Don't have this problem, vehicle's got nearly 98000 miles on it now.
Old Oct 27, 2021 | 09:59 PM
JD101b's Avatar
Mine smells like an old sock.
Old Oct 27, 2021 | 10:17 PM
Ml350 bluetec
I drive with the HVAC controls set to AUTO all the time. The AC unit is never turned off, so that is probably why I do not have the smell, the entire HVAC system stays "dry" all the time. I know on other car forums, owners of vehicles that live up north insist on turning off the AC starting around this time of year and leave them off until April?! To me that is a great way to create mold and smells and also causes AC units to leak Freon as the seals are now dried out from lack of lubrication.
Old Oct 28, 2021 | 08:47 AM
Leetom's Avatar
My 2013 ML550 was worked on while still under original warranty to fix the smelly socks issue. They told me they just sprayed a foam up into to HVAC core to sterilize and deodorize the system, but that it may return later. I dont run my HVAC on Auto, and only hit AC when needed, but when I do run it, I turn it off a couple blocks before my destination to dry things out. Suprisingly, I have not had the smell return...repair was like 7 years ago.
Old Oct 28, 2021 | 10:41 AM
Ml350 bluetec
I am confused, AC on means things dry out, turning AC OFF means nothing dries out......
I know in my other non-MB vehicle if I drive around without the AC on, it stinks big time.
Old Oct 28, 2021 | 12:21 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
The "recall" is a software update that turns on the cabin fan about 45 minutes after engine shutoff to dry out the evaporator and condensation pan vs. the previous setting that only turned it on ~10 minutes after engine shutoff. Every ML that has been brought in for scheduled service at a dealership sometime after 2017 would have automatically received the update.
Old Oct 28, 2021 | 03:56 PM
Leetom's Avatar
Reply to EL- The cold AC condenses the moisture out of the air that stays in the AC system, and drains out the bottom (the water you see dripping below car on hot days) . Leaving it on creates a wet system when shut off. Turning it off before, allows it to warm up, and dry out that condensation before shut down that causes the mold.
Old Oct 28, 2021 | 05:01 PM
Ml350 bluetec
Not sure I concur with that logic. Warm air allows more moisture to be collected by the air and therefore that air inside the HVAC system creates the smell. Not sure why letting the air warm up allows it to dry out. The humidity here in Dallas is exactly why we run the AC in the house longer to dry out the air otherwise mold forms everywhere....
However I do kind of see and understand your logic from the perspective of moisture collecting on the coils inside the HVAC while the AC unit is running and that is probably what you are concerned about and that is why you think turning off the AC system allows the warm air to dry out the coils inside the AC system.
But then I have never experienced this sock smell some of you have experienced either in my vehicle.
Old Oct 28, 2021 | 10:13 PM
Diabolis's Avatar
The A/C does dry the air that passes through it because cold air can hold less moisture than warm air. The A/C evaporator - what cools the cabin air as it passes through it - is at a temperature around 5C assuming that everything is properly working, and if the outside temperature is, say, 30C and it is humid, the outside warm air holds ~500% as much moisture, which turns to liquid (condenses) on the evaporator itself. The evaporator has a drip tray underneath which has a small drain hole and is the source of the "leak" that you see under a car after the A/C has been run, but some of the liquid droplets are too small to drip into the tray in the first place and stay on the evaporator itself (the evap looks just like a radiator or oil cooler with tiny aluminum fins), which is where mold usually grows if said moisture droplets are allowed to remain. That is why the "recall" turns on the fan as late as 45 minutes after the car has been shut off... I think the car runs the fan at about 10 minutes after shutoff and then again at 45 minutes to completely dry any remaining moisture droplets.
Old Oct 29, 2021 | 11:14 AM
Ml350 bluetec
@Diabolis Thank you for the clarification on the situation as well as what the "recall" is suppose to fix.
Old Oct 29, 2021 | 11:44 AM
threeMBs's Avatar
I'am not aware of any software "fix" to the issue (not in the States anyway). Lawsuit settlement does not mention a "fix", only reimbursements (prorated depending on year/mileage) for past repairs and free repair going forward for 10 years of the "warranty" period.
https://www.mercedeshvacsettlement.com.
Repeat, there is NO fix. Just reimbursements for past repairs and future repairs IF condition arises for unto 10 years/125K miles from the initial in-service date which ever comes first.
Old Oct 29, 2021 | 01:38 PM
Diabolis's Avatar
Well, I am likewise not aware of any lawsuits, much less of any settlements here - but I am in Canada where litigation is not our national sport.
The software "fix" to turn on the cabin blower fan is simply a software update that was implemented at some point in time (several years ago) and pushed out to all W166 MLs and X166 GLs brought in for service at authorized dealers. When a modern car comes to MB for service (at least during the warranty period - I am not positive about vehicles that are out of warranty) and they scan it through Xentry DAS, it gets the vehicle VIN and sends it to MB Germany. ANY SOFTWARE UPDATES APPLICABLE TO THAT SPECIFIC VIN ARE AUTOMATICALLY DOWNLOADED AND THE VEHICLE UPDATED. As part of said software updates sometime around 2017, the cabin fan was made to turn on after a longer delay (~45 min) after the engine was shut off to address possible mildew & mold formation on the evaporator (there is a TSB that stated this). I can only assume that the same update was pushed out worldwide or at least in the continental US as parts of it have hotter and more humid climates than we do here.
Old Oct 29, 2021 | 02:00 PM
Diabolis's Avatar
Here is one of the the TSBs addressing this issue... there were several others IIRC.
https://www.google.com/url?sa=t&rct=...FaGqNwd8Y4-YZt
Old Oct 29, 2021 | 02:11 PM
threeMBs's Avatar
Settlement was with MBUSA. My '15 ML (always dealer serviced) and my '19 GLE do not turn-on the fan 45min after. I'm in FL (as hot and humid as it gets), I do not have any issues with '15 and '19 (but I really take care of these cars). Know about turning A/C off "trick", but I never turn it off until I park.
Having said that, my former '14 ML had this issue once way back in 2015 and after dealer "treatment" it was gone (they did tell me it will come back at some point, but I traded the car in '16). My daughter's '16 GLC (operated 1K miles to the North of me) had this issue in '19. After replacement of filters immediately after smell appeared (no treatment) issues is gone.
Old Oct 29, 2021 | 02:19 PM
Diabolis's Avatar
I stand corrected on some of the details. According to the TSB (items 5b and 5c), the coding change turns on the cabin fan after 3 minutes instead of 1 hour afterwards, not the other way around. However, this may not be the last revision - I seem to recall that this was superseded by yet another TSB later that turned the fan on at both times...
