Airmatiic Malfunction compressed air sensor. W166
MB11 Icarsoft analyser displayed C15561C "the compressed air sensor for system pressure has a malfunction the voltage is outside the permissible range".
Air Suspension Valve Block 2123200358 ($125 AU) was ordered and installed , new fault came up suggesting an issue with the compressor.
Air Suspension Compressor a1663200204 ($269 AU) was ordered and installed, system ran up perfectly.
to replace the components I followed youtube
replacing the compressor was very easy (2 plugs, 1 pipe and 3 bolts)
whole task should only take a couple of hours if the parts are available (if not less if experienced)
NOTE. make sure when ordering 2123200358 get the one that suits your car (I initially ordered 2123200358 which suited the previous model assuming ordering the same part number the part would work on my 2014 W166)
Faulty valve block under front right wheel arch, mounted above the compressor
getting in behind the valve block with a Torx T25
I noticed at about 20000 Kms on the odometer that the relief valve was quite audible when the car was shut down (i just figured i hadn't noticed it previously) and now a replacement (aftermarket) compressor is fitted i notice the relief valve is barely noticeable when the vehicle is shut down. I suggest the compressor at 20000km was delivering very high pressure to the valve block which may have been partially blocked/ faulty and at 80000kms the compressor was worn out. (this is all speculative but plausible reason why both components had failed and bot required replacement)
