Aftermarket front camera and ambient lighting
Old Jan 14, 2022 | 07:06 PM
m4gnum's Avatar
C300 W205
Hi. I have a 2014 ML350. I purchased an aftermarket Android screen from Avin. Now I want to install a front parking camera and ambient lighting. Im not sure how to set it up and where to tap the wires into.
The camera works but only as a rear camera when I change the settings from OEM to Aftermarket camera. Is there any way to trigger the camera with any android app or with clicking any oem button? Where should I tap the wires to?
I purchased a full ambient kit from Aliexpress. I am not sure where should I tap the control unit to. Can I use any wiring in the center console?
Thank you!
Old Jan 18, 2022 | 07:15 AM
Doubleredrolex's Avatar
2014 ML550 AMG package
Does the light kit come with instructions? How do you control it (color and brightness) if you didn’t have Oem ambient lighting controlled through the steering wheel menu?
Old Jan 18, 2022 | 01:01 PM
we47b1me's Avatar
'22 GLE 350 | '15 ML250 | '87 560SL | '19 GLC 300 | '12 C250 (sold) | '02 ML500 | '98 C230
Thank you!
aftermarket ambient light is ghetto and will never stay in where you want it. you need to source the proper trim panels and retrofit it with MB genuine parts.
Old Jan 18, 2022 | 09:52 PM
you can get w166 specific aftermarket ambient lighting that replaces the dash panels and door panel inserts. Looks and functions exactly like OEM. You can even connect it to the OEM connectors and get it added using Xentry in the engineering menus so you can use the own steering wheel menu to control it. And it’s 12 color instead of 3 color and it’s brighter. Not sure what the dealership would charge for that though and if they even know how to do it. The only issue is that it costs about $1000 to buy the parts online from China. You can even get the burmester led motorized speakers that rotate and lift up etc. it’s all pretty expensive though. They are the same guys that make the 3 color to 12 color upgrade kits for Mercedes. At least that’s way cheaper because you only have to replace some controllers and wiring.
Old Jan 18, 2022 | 11:11 PM
we47b1me's Avatar
do more research -- it doesn't work like that. For less than $1000, you can do it the right way. Source: I did it.
Old Jan 19, 2022 | 01:04 AM
What doesn’t work that way? Please explain. Haha. What do all the OEM parts at Mercedes cost? I guarantee it’s more than $1000 for the wood dash and door panels with the light tubes and the LEDs with all the wiring etc. I upgraded my 2014 ML550 from the stock 3 color to the 12 color ambient lighting so I’ve done a bit of research.
Old Jan 19, 2022 | 12:14 PM
we47b1me's Avatar
Around 600 bucks sourcing the trim panels from various sellers on eBay. And about 100 feet of speaker wire to wire it all up. CKM car design is the only other way to do it right with Chris's 3 to 12 kit. You had ambient light in your truck to start with. This guy is buying a shi**y kit from aliexpress that you'd put in a Honda civic. You missed "retrofit" versus "upgrade". Much easier to upgrade if the system is already there as you had.
Old Jan 19, 2022 | 04:36 PM
drwolf's Avatar
2020 GLE350 2020 Toyota Rav4H AWD XLE
i was going to say yea go with @we47b1me and @Chris The Swede . WB47 did an ambient lighting mod, and Chris "CKM" sells the dash pieces specific for package 870.
Otherwise, do your homework and find the one that has it, its really not that hard to find out whether or not the car has it.
Oh, and about the front grille camera. The ones you see are part of the Surround-View-Camera system. You will not only need the front camera, you'll need both side mirror housings with the camera, but the rear camera. You'll need to reprogram comand to make sure it even works. Major PITA to do that.
My advice, just learn what to look for when looking for the packages you want.
Old Jan 19, 2022 | 04:44 PM
we47b1me's Avatar
Shame on you, it's 876!!!
Hope you are well, doctor.
Old Jan 19, 2022 | 04:49 PM
drwolf's Avatar
haha, Ive forgotten my codes a bit haha. Doing well, my friend. Hope your doing well as well! Happy new year to you and yours!
Old Jan 20, 2022 | 02:46 AM
Chris The Swede's Avatar
W222 S63L, ML/GLE350
The kit I have is very easy to fit IF you already had AMbient light. If not you need both trim and coding the comand as well.
