Retrofit android unit help
Old Aug 9, 2022 | 02:32 PM
Mercmerc's Avatar
Mercades ML350
Hi I have a ML350 2014 with a retrofit android unit, every time I accelerate it changes over from the android side to the command side and cuts out the aux music, any ideas?
Here’s a link to the YouTube video showing the problem.
YouTube link
any help would be greatly appreciated, thank you
Old Aug 10, 2022 | 10:58 AM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
It's either defective, incorrectly wired and/or you have issues with the power delivery to the unit.
Does it also happen when you're parked and rev the engine (i.e. slight voltage drop or interference without movement)?
Old Aug 11, 2022 | 02:28 AM
Mercmerc's Avatar
Mercades ML350
Solved!
hi thanks for the suggestion, I thought that as well so I got the multimeter out and everything tested out fine, turns out it was a software problem, I got the company I bought it from to send me a new software update, installed it on the unit and voila all working as it should!
