Looking for LED Driving Lights
Old Nov 9, 2022 | 09:26 PM
M~Factor's Avatar
2017 AMG GT, 2015 ML350, 2013 C300
I'm looking for an aftermarket LED driving lights that won't blind other drivers. The web are flooded (pun intended) with "off-road use only" driving lights but not the one that's on-road friendly. Any recommendations?
Old Nov 9, 2022 | 10:29 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Are you looking for full headlamp replacement? Or bulb conversion?
Old Nov 10, 2022 | 12:49 PM
M~Factor's Avatar
Looking for a stand alone add-on driving lights that I can attach to the bottom of the bumper.
Old Nov 10, 2022 | 02:59 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Would fog lights work?
https://www.jwspeaker.com/products/#application[]=automotive&product_category[]=fog-lights
I have a set of these mounted on the front bumper of my '87 Jeep XJ and have them on almost all the time. It is nice to light up the ditches with a wide beam light that still is low enough to not bother oncoming traffic.
https://www.jwspeaker.com/products/l...ts-model-6150/
I also put these in place of the sealed beam lights that were OEM on that jeep. Night time driving is a thing of the past; these are far superior to any other lights on any car/truck I've owned.
https://www.jwspeaker.com/products/l...0-evolution-2/
They're not cheap and they're worth every penny.
Old Nov 11, 2022 | 11:10 AM
M~Factor's Avatar
https://www.jwspeaker.com/products/#application=automotive&product_category=fog-lights
thank you for the recommendation. they look really good, very high tech looking. I looked it up on Amazon, it got bad reviews though. Not sure if I should trust the reviews there since it doesn't have much reviews.
Also, it does say "off-road use" but if you have them personally and you say its road worthy then I'll trust your judgement on that.
Old Nov 11, 2022 | 10:35 PM
2013 ML350 Bluetec
Note that buying from Amazon (as I did) means you won't get their warranty - you have to get them from an authorized dealer to enjoy that perk. The advantage I got from amazon was a greatly reduced price.
The JWSpeaker website has the details, and those details include that they are DOT compliant. That's the primary reason I spent the coin on them rather than a far cheaper clone.
I have both the headlamps and foglights set up on relays so the switches in the cab only engage the relay that sends power to the lights. Saves high current through old switch gear and guarantees the best power to the lights, even though there's probably enough electronics in each light to compensate for low voltages. Seems like I read somewhere that the allowable voltage input is anywhere from like 10-30VDC.
