Shuddering acceleration/gearchanges then error to low voltage to sensors
124700 The power supply of the sensors is outside the valid range
101E00 The signal voltage of sensor 2 of component WPF1 (accelerator pedal sensor) is too low
15FF00 The signal voltage of component YP39(DPF differential pressure sensor) is too low,
Are you family with this issue?
