Keyless Go Keyless Entry problem
Old Jul 28, 2023 | 11:52 AM
MarioMB350's Avatar
ML 350 Bluetec
Exclamation Keyless Go Keyless Entry problem
Hello. I got a year ago a ML with keyless entry and keyless go and today i observed that i cant unlock or lock the car through the door handle , i changed the key battery, i removed the vehicle battery connection,i tried everything that i found , and still not working. The problem appeared from nowhere , after i got home from work and everything worked fine. Now i observed that a message appears when i put the key in the central console and i press the start button . It says "Remove starting button,then insert key". Any advice what i can do?
Old Jul 28, 2023 | 12:43 PM
chassis's Avatar
2017 GLE350 4MATIC
Replace main and auxiliary batteries. Electrical oddities are normal on MBs if both batteries are not in near perfect condition.
Old Jul 28, 2023 | 12:59 PM
MarioMB350's Avatar
ML 350 Bluetec
@chassis the car batteries are great , anything that could be?
Old Jul 28, 2023 | 02:07 PM
chassis's Avatar
2017 GLE350 4MATIC
When (year/month) were the main and aux batteries replaced?
Old Jul 29, 2023 | 11:37 AM
MarioMB350's Avatar
ML 350 Bluetec
I will check!
i remembered that the last time i used the car before the systems stopped working was when i rolled down and up the windows with the key thats the only thing i did at the car before this problem. Only with the key not opening the doors ,i just pressed the unlock button like 2-3 times to roll down the windows and 1-2 times i pressed the lock button to roll up the windows and then when i get back this problem was
Old Aug 28, 2023 | 07:24 AM
DiabloDainese's Avatar
ML350 Bluetec
Have you tried resetting the key? Pop out the keyless button from the ignition. Insert the key and turn but not fully to start. Wait a couple seconds then turn off. Remove key. Reinsert button. Then try. The dealership explained this when I got a new key so it will code to the car. Maybe this will work?
