Pad Replacement Funtion
Old Oct 15, 2023 | 05:57 PM
MRML3502D's Avatar
2014 ML 350
My rear brake pad fell off, and I must add a new one onto the right rear side. I tried to put the car in pad replacement mode, but it did not finish. It gives me the option to try again, and when I press ok, it does not move to attempt to move to the fitting position anymore. It is in the first ignition position, the parking break is not on and it still will not try to move to the fitting position for a second time. What could I do?
Old Oct 16, 2023 | 07:40 AM
mike919's Avatar
86 190E 2.3, 2014 ML350 Bluetec
Your brake pad fell off and you want to simply add a new one? If you don't understand why that would be a bad idea you need to take this to a shop.
Old Oct 16, 2023 | 09:32 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
I hate it when Darwin tries to go beyond the call of duty.
What mike919 said. Take this to a shop.
