2015 ML350 transmission
Old Oct 16, 2023 | 09:05 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
The transmission in my 2015 ml 350 4matic with 92.000 miles is starting to act up. Sometimes when starting out after initial movement when it tries to shift up the car will violently jerk .. One time the engine cut off and all the dashlights lit up. At other times when shifting to a higher gear 6 to 7 (under light acceleration) the trans flairs between gear. I did the transmission reset and it seemed help for a while but it some back. This has happened about 6 times in the past month.
Transmission fluid had been changed per owners manual at Mercedes Dealer.
Thoughts ?
