Navigation Problem
Old Nov 8, 2023 | 06:57 AM
eros1's Avatar
ML
Navigation Problem
Hello,can someone help me in the ML 2013 car, when I press the navi button, only this is displayed, the maps and nothing else appear, does it improve only with the map update or what is the problem
Old Nov 8, 2023 | 07:41 AM
bobofthenorth's Avatar
2013 ML350 Bluetec
I assume you know this but just on the off chance you don't - this button should change that screen for you. If it doesn't then your problem is above my pay grade.
Old Nov 8, 2023 | 07:45 AM
eros1's Avatar
ML
Thanks for the reply, but I tried that button and nothing is changing
Old Nov 9, 2023 | 09:20 AM
Mikey178's Avatar
2013 Mercedes GL350 Bluetec (X166) & 2019 Mercedes A220 (W177) & Retired 2008 Mercedes C300 (W204)
I will ask the obvious, but did it work before and was there attempts to update maps recently? Just trying to rule out a corrupted file.
Other option is try going back to the radio screen, push the control knob (#11) up and then select the navigation from there. Does it make a difference? Also, if your on that screen that you shared when you press the navigation button, if you press down or left or right on the control knob (#11) do you get any options?
