HELP! P01685 AFTER bank 1 intake VVT CHANGE
I have tried to research as much as I can on here before posting. I saw threads on trying to move hall wheel a few mms, didn't work for me. My hall wheel was perfectly lined up before me forcing it; no worries, have a new mb cam on the bench for install.
My main question is, Is there something I'm missing with reinstall? I have r/r phaser probably 4x now, chain tensioner out, mark links, lock down cams, reinstall, everything is lined up, button in all back up. On restart it is slow to start, like 2-3 seconds then fires off. When running it revs fine etc but throws code instantly. scanner says advance on intake cam ordered 35 degrees, actual 42. I have swapped solenoids, cam sensors between bank 2( US driver side) and it doesn't care still only p01685 on b1/Intake. Does vvt phaser need to be preloaded somehow before torquing the "valve control bolt" (also new installed) or something and if so, how? Does it need to be programmed with scanner? I'm beyond frustrated at this point. I do have another phaser and new cam to install hoping my last phaser was defective but I wanted some expert opinions before I just keep throwing parts and time at this thing and not actually fixing anything.
Also, when looking at engine, valve covers off, intake cam is centerline of engine, talking about bank 1 (US passenger side) is advanced clockwise?
this should apply to m276/m278 engines along with most other mbs as I've read its common across most engines with vvt. I do not want to bash or complain about mb engines, looking for help; when they run I love them...
Thanks for any help/ suggestions
Tim
