2015 ML350 . Coolant Leaks from top of the radiator
I have the same issue - same side but it doesn't leak enough yet to be a problem for me. I would not recommend any "stop leak" additives as they can collect in other areas (besides your radiator),
Unless you have a local shop that rebuilds them, you can pick up an off-brand for $250-300 USD online. The Mercedes brand ones are around $600
Ronnyb (03-01-2024)
2004 E 500 4MATIC Wagon; 2015 ML 350 4MATIC; †2003 C 240 4MATIC Wagon (2003-2022)
One last word of advice: I was talking to my mechanic the other week about preventative maintenance on the cooling system. Specifically, I was exploring coming up with a list of components to replace preemptively when getting my serpentine drive belt, pulleys, tensioner, thermostat, coolant expansion tank/reservoir, and coolant flush service done the next time I see them (100,000 mile service). The thermostat housing is plastic, which gets brittle and eventually also leaks...as well as the fitting my mechanic describes in (yes, he's the mechanic with whom I've had these sorts of discussions over the years...and, now, he has a social media presence). I'm also looking into getting the plastic fittings by the firewall going to the heater core replaced before they crack and spray coolant, which they will eventually, in addition to several other hoses and fittings... You might want to consider this, since these are very common failures (much worse on the turbo-charged models).
mike919 (03-01-2024)
E55, GLS450, GL63, GLE350
It's a two-person job to get everything aligned again. I would recommend paying a competent independent to replace. As far as OE vs aftermarket, it's clear the OE is crap so I would recommend going with another manufacturer. Mine recently failed and started leaking too. It was a PIA job.
chassis (03-01-2024)
