"friction/vibration noise" 2013 W166 ML350d BT,
W166, 2013, ML350 CDI BlueTEC
When I start driving the car, on full left or full right steering-wheel I hear a "friction/vibration noise" coming from underneath the chassis (not engine)
only when I start driving
2013 ML350 Bluetec
Are you holding the steering wheel tight against the stops when this happens (don't do that)? It puts a LOT of stress on the steering pump, tie rods, etc.
Turn the wheel fully then back off a tiny bit so you're not on the stops and see if that makes a difference.
