2014 ml350 sunroof leak
Old Sep 4, 2024 | 07:26 PM
sixers's Avatar
ML
I checked the seals and cleaned them, poured water down the sunroof drains and the water dispensed at a fast rate to the wheel wells. The sunroof glass covers the front driver and front passenger side. The second row seat and trunk are covered with metal body. The sunroof leak is large and located at the back side of the sun roof closest to the second row. It only leaks when the high powered jets at the car wash go over the sunroof. Unfortunately the amount of water that leaks through each wash has been enough to stain my headliner. Any ideas in how to fix this issue. A Benz dealership told me I would have to purchase the whole sunroof setup which costs a few thousands dollars as the seal is not sold separately according to them. Any input would be much appreciated.
Old Sep 5, 2024 | 08:37 AM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
me, I'd just avoid the carwash.
Old Sep 5, 2024 | 03:06 PM
vinceC's Avatar
2014 ML350 4Matic
I assume you have the Sliding/Tilt Glass sunroof, not the Panoramic roof. There are drains at the rear of the sunroof frame. Did you clear those also? They are probably hard to reach. Some folks clear them with a length of trimmer line.
Old Sep 5, 2024 | 04:09 PM
sixers's Avatar
ML
I just cant seem to get back there regarding those back rear drains. yes I have the sliding/tilt glass sunroof not the panoramic roof. any tips in how to get back there?
Old Sep 5, 2024 | 06:52 PM
vinceC's Avatar
2014 ML350 4Matic
I have the Panorama roof so I don't know how to access those drains from the top. Maybe someone on the board can tell us where the drains daylight under the car. If you know that you might be able to blow back from the bottom or run some trimmer line from the bottom up.
