2014 ML350 W166 Bluetec AC/Heater Tempature Controller
Old Dec 28, 2024 | 09:09 AM
Bluetec Guy's Avatar
Hello, I recently started having issues with my HVAC system. I suspect it might be the tempature controller as it randomly switches from defrost (heat) to vent (cool) when its in auto mode. If I select manual I can control the fan speed and turn it on and off, but it will not switch from defrost to vent or floor. A new controller is $1100.00 from Mercedes, but I have found used controllers on Ebay for 100.00. It would take a chance of buying one off Ebay if it's plug and play to see if that is the issue before I take it in to the dealer. I have read blogs where they say if the controller is replaced the replacement controller needs to be programmed to function properly and there are blogs out there that say if you purchase the exact OEM part number you don't need programming. None of the blogs are related to the exact vehicle that I have so I'm not sure which one is accurate? Any help would be greatly appreciated.
