Carbon Cannister Filter
Old Yesterday | 01:39 PM
Halexb's Avatar
ML350
2014 ML350
Getting P0455 errors. CEL light on.
Changed purge valve. .. nope
Changed gas cap... nope.
Smoke tested hoses in engine compartment (to/ from purge valve etc). no leaks
Attached smoker to gas filler.
Smoke outta carbon cannister.
Removed cannister and the small filter on top (see pic) was FULL of dust. (I race at El Mirage dry lake for years... lots of dust)
Cleaned out the filter, cleaned valve and o-rings. Lubed o-rings.
CEL off for a week (~100) miles.
Back on yesterday.
Maybe the valve is corroded or o-rings in the filter piece bad...
Can't find the little piece online.
Is a new one available?
It's the small round thing in the attatched picture.
Old Today | 09:19 AM
Mikey178's Avatar
2013 Mercedes GL350 Bluetec (X166) & 2019 Mercedes A220 (W177) & Retired 2008 Mercedes C300 (W204)
Do you see any part numbers on the part you are looking for? If not, probably look for the canister and then see if the filter comes with it.
Try this link with your VIN as a starting point: https://www.mboemparts.com
*See this link: https://www.fcpeuro.com/products/mer...mer-1664700359 - Looks like it's 1 assembly.
