tranny problem
hi all anybody know about these speed sensors an this plate in the e55 tranny got three codes p2500 p220a p2561 would like to know if anybody done this job an is it hard or are there other things to check other than fluid level
im also a tech jus not a lot of benz exp .. the pilot bushing in the back of the crankshaft ? an these parts from dealer or aftermarket ?
the connector leaking I cleaned it out perfect last night its still dry car doing same thing .... these plates what are they just a conductor wheel like an abs ring gear ? an do I need new gasket for valve body ? srry for all the q but its a problem just to get parts for these cars an if I pull it out an need something else jus don't want to get stuck thx a lot for your help
sooo sensors should fine ? or jus change em so I don't hav to back in there also how can I check the fluid other than with a scan tool
thx for all your info ..... so your saying the sensors come with plate or jus att to it an don't need to change ... an in the pic u sent its showing the connector att to the plate ? or your saying change the connector on the tcm side ? srry for all the questions but u seem to know thus tranny well I don't at all an want to go in once an enjoy the rest of the summer as its almost gone again
thx a lot your a great guy lol ... p2500 p220a p2561 are the codes for this I got .... got ya now I see the pilot bushing bolts to the conductor plate sooo ill just make sure to put the speed sensors an solenoids in the exact place I take them out ill jus lay it down an switch em one by one shouldn't be any problem that way thx again
is there a gasket for the valve body ?
I am having the same issue I think......the codes I have are P2561, P220A, and P2562. When I get on it (take the rpm towards 2,000) I start to hear a whine noise and soon afterwards the car goes into limp mode. Did you have the same issue and if so did you get it fixed? The shop said the car shifted just fine when they drove it and they cleared the check engine light. I drove it home and I started to hear that noise again and the car almost went into limp mode. I am worried!
Hey bcurtis... sounds familiar. What have you had to fix?
Futom-sorry for late reply. My most recent issue was a solenoid. I think there are 4 or 6 of them and only 1 was bad.
Originally Posted by bcurtis
(Post 6328070)
Once the car has been off for a while the dirt drains from the filter back to the sump and it'll run fine for a while again. Replace the filter and oil, also drain the torque converter if you can. If you cant drain the TC then you will most likely need to change the oil and filter again in a few weeks. |
tranny problem
You need to replace the conductor plate and depending on what transmission it is you might have to replace the valve body I do these all the time it's
common |
