E63 Vibration question??
Hi folks, I published the post below in the W211 AMG section after buying my car. There is a very slight vibration at initial roll off the line then goes away. Just saw this forum, so I thought I'd post here. Please let me know if any thoughts after reading this post. Everyone tells me it's 'normal'... Thanks a bunch!
Tom https://mbworld.org/forums/w211-amg/...n-shudder.html |
Ok, noticed a lot of folks have browsed the thread. I used to have an 05 E55 and it was rock-solid.. Now with the E63 I have noticed that when you hold the throttle at 1,000 to 1,200 RPMs in park that you can really feel the vibration. Maybe I need to post the 'why' question on the AMG forum.
I happen to ask a similar question today whike at the dealership. A forman at mercedes told me its normal with the new 63 engines. U really feel the entire power of the engine through the chassis and the entire car and or truck. This was done so the customer could feel the entire power range of the motor.....enhances the experience. Obviously within normal vibration. Complete shaking should be checked by the dealer .... Njoy Njoy
I too am experiencing this issue. In neutral rev between 1100-1250rpms and there is a vibration present. Engine does not sound like misfiring and no check engine lights.
Anyone care to chime in? |
Engine mounts
Injectors Vacuum leaks All could potentially cause these symptoms. |
