M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
IC Pump Test?
Old Oct 12, 2009 | 04:45 AM
guardrail's Avatar
CL65AMG
IC Pump Test?
Is there an actual test for the intercooler pump?
I've read threads about replacing them, how do you know for sure it's bad?
Old Oct 12, 2009 | 09:51 AM
JAYCL600's Avatar
new balance
your IC pump is on the drivers side lower front bumper. With the key on and engine off u can usually hear the pump. With the engine covers off there are two check/schrader valves on the lines feeding the IC cores, while the pump is on depress one of the valves and you should see a steady stream of fluid released from the valve.
Old Oct 12, 2009 | 10:19 AM
guardrail's Avatar
CL65AMG
Got it.
Thanks!
Old Oct 12, 2009 | 05:18 PM
2003 S600's Avatar
2003 s600
My pump is on the passenger side right behind the small amg grille. It does not run when engine is off unless you wire it otherwise, but with engine on, you can put your hand on the hose inlet and feel the vibration of the flow if it is working.
Old Oct 17, 2009 | 07:43 PM
Akademiks's Avatar
SL600
If a stock E63 ever pulls away from you, you know your IC pump is proper f.cked.
