Turbo diverter valve not working well?
Anyone have diverter valve problem, the thing on front of turbo aka blow off valve. At part throttle, mid boost if I let off gas, I hear a low pitch sound comming from left side engine area sounds like boost surge where the blow off valve is not opening to relieve boost pressure. Also, how do you check the valve, and where can u get a replacement?
I dont know if anyone having this issue. If youre are mid boost and you let off the throttle the DV will open to relieve pressure, any sound your hearing is boost being bled thru your DV.
