Trapping High 130's
02 S500 Sport
Trapping High 130's
I'm surprised the E55's trapping already 135 from their V8 Kompressor.
What the hell no one can get this massive TWIN-TURBO animal to get around 140?
02 S500 Sport
Ok, but besides that are there any aspirations to try get High 130's. Even a Low 140? I know its almost 5000 pound car but the IMO the V12TT should be the king of the road ! I'm not saying its not as of right now. I have a massive amount of respect for that engine. But VRP825 didnt get the job done to hold the record trap.
Can it be done?
Can it be done?
PLATINUM SPONSOR
It seems that even the 65 V12`s run out of air after the 8th mile.. All the cooling mods and tunes are nice but the motor was designed to move the weight.. Low to mid brutal TQ! IMO, the throttle body is to small, cams may be too and down pipes may also be desinged for low to mid range power..
Most of the V12`s are really fast at the 8th mile but final trap is low.. It may just be a couple of small changes to get that 130mph.. At 130mph, it will ET better than any benz on the planet!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
The turbos on the V12's are too small..until that issue is taken care of it will be tough to trap 135+, think about this... how many mods it took the E55 to trap 130??...a lot right? now, spend some time and energy into producing some mods for the V12 and you might get a 135+ trap.
The V12 ONLY has a tune and a set of intercoolers!!! Now add upgraded turbos (intake and exhaust wheels), better throtle body and a few other goodies, you got yourself a 4600+lb whale trapping 135+...that's my take.
Not to mention the E55 is significantly lighter.
CL65
The V12's are very restricted as far as exhaust side of the manifold. Marcin is working on a solution right now. If my calculations are correct, 140 mph should be attainable at any track and without nitrous. This involves different turbos and manifolds however. Don't know how the transmission will respond to that power level.
SL600 (1000 hp), Cayenne S, 996TT EVO GT750, F430 Spyder,A real Ford GT, 08 Gallardo Spyder
+1
Has anyone seen upgraded turbine wheels for the stock turbo's? It looks like there is very little room in the housing to get much bigger. If memory serves the turbos are the same size as the 911 twin turbos, so there should be some upgrades available, possibly???
Marko, I think your aproach of a new turbo and manifold combination is right on target. The flow charachteristics of the stock manifolds has to be terrible.
CL65
The exhaust housing is cast into the manifold. It would be very difficult to machine it for larger wheels. The merge section (where all the runners collide before entering into turbine housing) has a diameter of less than 2". That's right, 6 cylinders discharge exhaust into an diameter of approx 1.75 inches. As far as the "cold" side, the compressor housing is small already and you would run the risk of compressor surge should you install a wheel too large for the housing. Keep in mind that these things spool instantly. I think there is power to be had with the stock turbos with a properly flowing manifold. But then if you're going that far, you might as well go all the way.
there is another thing - 140mph is 4th gear... as there are only 5 gears the car is geared very tall and once in 4th (and even more so 5th) the thing almost falls on its face... relatively speaking that is
thus my thinking is that a shorter rearend might provide formidable results... i would for one would gladly trade some top speed for some better acceleration up to 160 or so...
alex
few cars
alex
few cars
. Totally agree with you Brooke.
There's a reason why some of these tracks like Sacramento and MIR holds records, plain and simple they are much faster and quicker than most. Sacramento is known for it's outrageously high traps and MIR for their excellent track prep and low ET's. I haven't raced at a ton of different tracks but enough to know that I'm lucky to have a sea level track near by that will give me chances to race in negative DA. I honestly believe if some of the other fast cars out there had a chance to race at either track or similar DA they too would have the chance at breaking records...no doubt. Unfortunately a lot of people won't have this chance which in turn means that record setting runs will be unlikely.
BTW... a lot of trial and error went into my car but the end result has made me very happy. I've only had my car for over a year and I'm very proud of my accomplishments on this platform.
I look forward to seeing your car run Jody !
There's no doubt the twin snails will be faster and quicker than the E55's, they should be. I'm surprised no one has figured out ways of upgrading the turbos yet, once that's done....game over .
My car...I could only wish it would be as fast as yours.. : time will tell.
In terms of the snails Marcin might be working on something for it, too bad I sold my 65, won't see much of the benefit.
Your car is an animal man, and it shows by all the hard work you have put in it. I take nothing away from it.
It's funny because I was thinking the same thing when I watched your 65 go 10.72 @ 128...over and over again. The benz might be going bye bye pretty soon anyways, it's like 30% - 70% in favor of me keeping it.
BTW....there's a guy from LA selling stock 65 turbos because he upgraded. Maybe you guys should look into speaking with this guy if you already haven't. Just a thought.
