V12 Biturbo surging....anyone else get this?
Guys,
I have the exact same phenomena outlined in this post:
I never ever noticed it until I did my exhaust work, making the car louder. I chalked it up to something with my ecu tune, but after doing some research on here, and other forums, it appears to be happening to other, non-modded cars.
Anyone else have this? And if so, what was your fix?
Hello all !
I have a 2004 SL600 with about 38k miles on it. It is my first Mercedes and it is by far my favorite car ever. While driving the car seems to surge, jerking me back and forth. It happens usually at 1200-1600 RPMs at about 40-45mph. It does it at other speeds/gears but always in the 1200-1600 RPM range. It is very noticeable, my passenger can feel it without me saying anything.
The RPMs jump about 200 up and down. The speed also jumps 1-3mph. It does it with the accelerator pressed or while coasting.
At first I thought it was the accelerator, but it does it with the cruise control set too.
I took it to the dealership and they couldn't reproduce it. They checked the codes and nothing was set. I've checked the codes everyday and nothing is set.
I am hoping someone here has had a simular problem and can give me some hints to help the dealership diagnose the problem.
V12-Biturbo
Mines done it as well since bone stock... I just ignore it, dealership couldn't replicate lol! ONLY Happens @ low rpm's w/part or little thrtl little rev blips. Doesn't jerk me around like the quoted post above @ all, just fluctuates about 200 rpm's up n dwn bizarre.
With no mufflers, it sounds like "wooooo-uh.....woooooo-uh........woooooo-uh" while it's bouncing.
What the hell could this be?
2007 E63, 2006 C55
RE: SL600 Surge
Mine does not surge at all. I saw your post and tested it. Smooth as can be with the....lazy.....stock tune, if adding a tune causes it I'll post it up pronto.
I think I had something like that happen a couple of times (probably over a year and half ago)...but not while in gear. It only happened after start-up in park....the revs increased without hitting the throttle...and then dropped back down to idle after a couple of seconds. Not sure it is the same thing.
Tom
Tom
I installed a brand new set of BMC air filters and the surging didn't present itself today, when I took the car in for service.
The oem paper air filters that I took out were still very clean.
Weird.
Weird.
They were very mean looking.
Car is still at the dealer for a small tranny leak, so I haven't been able to drive it. There is a sensor at the bottom of the tranny pan, and the gasket for that sensor is leaking a bit.
I'll probably pick it back up today or tomorrow, and I'll know for sure. Twas encouraging that the issue didn't happen on my to the dealer, as it was completely reproducible every time the car was driven.
Will update....
Will update....
Will update....
Will update....
Tom
I'll check the invoice when I get it back to see labor hrs and parts cost.
**EDIT**
Just talked to my S.A. and he said that job is about $250.00 or so outside of warranty.
Tom
Platinum exclusion list:
Brake linings, brake drums and rotors, disc brake pads, standard transmission clutch components, air bags, solar powered devices, hinges, glass, lenses, sealed beams, body parts and/or panels, trim, moldings, door handles, lock cylinders, tires, wheels, batteries, light bulbs, upholstery, paint, bright metal, freeze plugs, heater and radiator hoses, exhaust system, shock absorbers, audio, security or other systems not factory installed, work such as front-end alignment or wheel balancing, constant velocity joint boots, safety restraint systems, cellular phones, electronic transmitting devices (except for those specifically listed under silver, gold, or gold plus coverage), radar detectors, appliances, near object avoidance systems and all laser radar cruise control components, vinyl and convertible tops.
http://www.fidelitywarrantyservices....tion_plan.aspx
Yes sir. Fidelity (Platinum) covers just about everything except brakes and tires.
Tom
I'm ready to confirm that changing the air filters has remedied my surging issue. I've driven the car three times now since I swapped filters, and the surging was not present at any time during those three outings.
So very weird, as the OEM paper filters I pulled out look very clean.
W220 S65 AMG
I don't know if it's the same issue, but sometimes at low RPM it's really touchy and a little jerky, but this could be due to the SB.
My car usually acts weird when you are on the throttle and then you suddenly let go, it feels like it has a hard time down shifting and kind of jerks you forward.
I have the same low-speed/RPM surging in my 2005 SL-600. I have the K&N air filters and it's no different than the stock filters. The BMC's look the same as the K&N's. Think they'd perform any differently? I'd be willing to try them if it would make a difference.
All I can say is that from the moment I installed the BMCs, up until the typing of this response, I have not experienced that surging. It's completely gone now.
2005 SL600, 2016 ES300h, 2012 Hayabusa
any updates? I noticed a small amount of surging on the interstate in my sl600, but it was only around 150 rpm or so
V12-Biturbo
Surging/Fix UPDATE...
Surging problem totally gone/fixed, was getting worse before left Coil-Pack (Ignition coils) after replacement under Warranty thank god! repair inc SRS sensor & new struts/shocks for trunk $3000 I paid outt've pocket for brand new direct replacement SL65 Spark Plugs, since they were doing the coils the labor was virtually nill @ least on (1) side of engine...
Now part/full/mid/or lifting from throttle = smooth sailing ZERO RPM surging!!!!
BTW I love my friggin' SL600 more than ANY auto I've ever owned/modded old Spark Plugs (almost 48k miles looked PERFECT Jeremy's ECU tune is obviously making the engine very happy, MB-tech showed me old plugs & we both couldn't believe how good they looked, he said they looked as if off a car w/10k miles just tinge light brown sut, no corrosion/oil/etc...
