ABC Valve Block Removal
For those that have tackled the ABC valve block, how did you loosen the line connections on the valve block? I tried but they are way too tight. Using an open end 17mm wrench and tapping it with a hammer only got 1 out of 5 loose. Any Ideas?
http://www.2carpros.com/how_does_it_...ine_wrench.jpg
That looks safer for the face of the nut. Thanks. I am not having trouble with it rounding the sides, it stays solid on the nut, just cant get enough torque on it to loosen it.
