2003 cl600 oil cooler
would anyone know how to replace the oil cooler on the 2003 cl600 biturbo? I know where it is on the non-turbo v12. is it at the same location or is it easier to replace?
any help would be greatly appreciated.
thanks
thanks
Look in the center of the bumper below the lisc plate and there it is. You have to remove 4 10mm bolts to get the bracket loose. From then you need a large wrench to remove the fittings on the cooler.
