Replaced Driver Side Ignition Coil - This is what I found
Install and removal was pretty simple thanks to FormulaZR's DIY.
Once the coil pack was off this is what I found -
All the valve covers bolts were a bit loose I had to tighten them
4 spark plugs were also pretty loose
Probably the vibration of the engine is causing them to get loose over time
If anyone feel comfortable removing their ignition coil, I would recommend doing that just to make sure everything is tight and sung.
