M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
what are the differences between a sl600 engine and sl65 engine
Old Apr 28, 2013 | 09:39 AM
parish8's Avatar
is570t(is300, ls1, turbo)
hello all. first post and i am considering a sl600 or sl65 and was wondering the differences between the motors and i suppose the cars too. i plan on modding the thing and if one motor is ready to hold a lot more power than the other i would like to know.
i know the sl600 has 5.5L vs the 6.0 of the amg. beyond that it gets a little foggy.i have seen mention of larger turbos and injectors on the 65 but cant confirm it. does the sl600 engine have oil squirters under the pistons? does one motor have better rods or pistons or crank or anything?
now on to the rest of the car.
i have the impression the sl65 has a limited slip rear end and the sl600 does not?
do they have the same brakes?
any info would help. a sl600 is a lot less money and i am trying to figure out of the 65 is worth the extra money.
Old Jun 22, 2013 | 02:54 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Here you go:
Such as this CL65 AMG. Fitted with a bored-and-stroked high-pressure-turbocharged version of the V-12 engine found in the stock CL600, the coupe produces 604 horsepower and a rib-cage-flattening 738 pound-feet of torque between 2000 and 4000 rpm. Expressed in metric terms, the torque output is a round 1000 newton-meters of drivetrain-twisting force.
The really funny part of all of this is that the output had to be reduced somewhat in the interest of transmission life. There is another 200 or so newton-meters to be had here, and the aftermarket loonies will undoubtedly go looking for it. But Mercedes-Benz will not warrant that kind of exploration, even though this AMG car is covered by the Mercedes warranty with no transmission upgrades beyond new clutch discs and revised control logic. There are, however, beefed-up driveshafts and hubs farther downstream.
To get this kind of urge, AMG increased the cylinder bore by 0.6 millimeter and lengthened the stroke by six, ending up with 5980cc of engine displacement. AMG-spec forged pistons with thicker wrist pins fit inside the new holes, where they are cooled by an upgraded oil-spray system.
The combustion chambers were reshaped for a 9.0:1 compression ratio, and the intake camshafts have higher lift and longer dwell. Both turbochargers have larger housings and wheels and pump nearly 22 pounds of boost via a front-mounted air-to-water intercooler that is about 70 percent larger than the stock item.
According to AMG engineers, this results in a 25-percent reduction in intake-air temperature at full load. Naturally, the electronic engine-management system had to be reconfigured for every aspect of operation, including those revised waste-gate pop-off parameters. A redesigned aluminum and carbon-fiber-reinforced-plastic engine cover enlightens any bystanders who somehow have missed the prominent AMG and V-12 biturbo badges adorning the bodywork.
R.K.
Old Aug 16, 2013 | 04:45 PM
RoCL's Avatar
M109R
Originally Posted by radride
Here you go:
R.K.
Just for the sake of acknowledging your outstanding response...wow..
These details are hard to come by. How did you learn about this...if you don't me asking?
Old Aug 7, 2016 | 10:22 AM
MB-CLS500's Avatar
CL600 W216
Here you go:
R.K.
I know it 3 years old post but. This question bothers me everyday and I cant find the answer anywhere I have cl600. So Can you intall 65 cams on 600 and benefit from it?
Old Sep 6, 2016 | 02:31 AM
ZephTheChef's Avatar
2004 S600
I have heard it both ways, that they are the same cam, and that they are different. Don't know which is true.
Old Sep 7, 2016 | 02:34 AM
AMG-Driver's Avatar
SL65 R230
They definately are different, I experienced tuning in midrange is better with the 65 than with the 600. I am not sure if a change is worth it for max.HP at high RPMs. There are other options to gain more power for less money and labour costs.
