M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
CL65 Knock sensor code
Old Aug 20, 2013 | 10:22 PM
jason3977's Avatar
04 E500 20in brabus monoblocks 1 serious 500E & 91 300CE 2JZ 2005 CL65
Has anyone ever had to change a knock sensor on the 2005 cl65? I got 2 codes 1 for knock sensor front right and the other is... load limit is active. I was told the knock sensor will retard the timing causing car to be sluggish!?!? I bought a new knock sensor and will be installing it tomorrow. But just trying to gather some info if its not the sensor. Thank you
Old Aug 21, 2013 | 10:03 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
did you clear the codes and check to see if they come back?
good luck trying to get to them!!!
Old Aug 22, 2013 | 04:07 PM
jason3977's Avatar
Not good luck to me...Good luck to the mechanic lol.
I changed it. It was the problem!!! Passenger side front. Motor mount had to move!!!
