CL65 motor mounts / vibration Q
Opinion requested regarding an '05 CL65 w/ 66k miles. Car has a whine / vibration, louder once car is warmed up than when first started. Not audible from outside the car but relatively loud from inside. Pitch is dependent upon rpm, sound was present before the following work was done.
In the last four weeks:
1. ABC pump has been replaced (legit as psi dropped to sub 20 bar once warmed up, around 192 bar while cold),
2. all ABC lines in the front end of the car have been replaced,
3. front accumulator has been replaced,
4. pulsation damper has been replaced.
5. Idler and tensioner pulleys have been replaced
Thinking motor mounts have collapsed sending vibrations through the frame.
But the odd thing is, the motor exhibits no visible vibration or rotational (torque) movement, either from an initial start (hot or cold) or from rev'ing the motor. Nothing. It acts like it is bolted directly to the subframe w/o any rubber mounting.
1. Is the lack of any visible engine movement normal for the 275?
2. Has anyone who has replaced their mounts have any guidance as to how to tell if the mounts are actually collapsed besides simply assuming at 66k miles they are going to be shot?
3. Other opinions as to what to consider?
Thank you in advance.
Dave
Houston
So, have my next project escalated up a bit on the schedule.
dave
